Speaking of feel .
I Have had 2 x XS 650 SE US Custom 1980
Should be the same bikes.
Points on both originally
Both bought used as "Last owner " bikes
I am not certain that they were stock but I do believe so.
But strangely rather big differences in how they behaved on the road
No 1 had stiffer suspension most likely after a crash giving the fork a hit And more on /off snappy throttle response even though compression was not so good. at the end Bumpy on highway but better cornering
Rock and Roll ...
No 2 had soft suspension especially in front ..softer cruising .But opening up on going out of a roundabout
Fork extending and having some leaning on the bike.
You needed to be awake ..and a couple of times after curves I was on my way off. Both sides of the road
More like a Gentleman's bike.
There are adjustments possible to do and I did not work that much on the carburetors.
That is the plugs looks right and no vibrations but not the same Snappy response
No 1 was mostly ridden with points and No 2 with Boyer Bransden I suspect the points be a reason.
I now have No 1 fork tubes on No 2 bike stiffer front and handling is better.
I suppose it would be possible to adjust and replace. But the impression is that the bikes can
change characteristics. With time and wear.
Rock and Roll ...
