You should be fine.
You should be fine.
There you areOK, time for the proper front wheel install technique - have the fender and the clamp on the bottom of the left fork leg loose, and hand tighten the axle. You want to make it fairly tight so the axle and wheel get pulled over tight to the right fork leg. Stick a bar of some sort through that hole in the left end of the axle to hold it from turning. A #2 Phillips screwdriver usually fits nicely and works well. Once that's done, you want to take the bike off the centerstand and pump the forks a few times. I don't use the front brake for this as it only grips the right side and can induce a twisting action into the forks. Instead, I like to butt the front wheel up against something like a wall. Pumping the forks like this will allow the loose left leg to "center" and align itself on the left side of the axle. I then carefully put the bike on the sidestand and tighten the clamp on the bottom of the left fork leg. Then you can centerstand the bike again, do the final torquing of the axle, and lastly, tighten the fender.
Good to knowThat looks good and correct. That's how they end up, with that cross hole in the left side of the axle just showing, and about a 1/8" gap between the speedo drive and the inside of the fork leg ....
And on the nut side, just a thread or two protruding out of the nut .....
If I torque the axle nut at all (I didn't for years, lol), I just bring it up to the minimum spec then hand tighten it further until I can get the cotter pin in. I know it at least met the minimum spec and is now tighter because of me aligning the nut for the cotter pin. The reason I didn't torque the axles in the past is I hadn't found that torque spec given in a range yet, just as a single value. Well, a single value for a nut that gets a cotter pin is just plain silly. You know it won't be aligned for the pin at that value, lol. Also, the single values given in most of the torque charts are quite high, pretty much at or near the max of the "range" spec. For the rear, that single value spec is something like 105 ft/lbs. I tried torquing it once and could barely get it that tight, so I just went back to tightening them by "feel", making them "good and tight". When I finally did discover the torque spec as a "range" ('77 torque chart), after tightening the axle nuts "my way", I put a torque wrench on them set to the minimum spec, and they were both good. So, it seems I was tightening them up enough by "feel" all along.
Thanks!!Good to know
Now to get past frigging GOLFThanks!!
Mikey it looks like you have leds for a dual element light (stoplight) you need single for the turn signals.tried them and from the way the design on the bottoms are, they won't fit
I got along just fine for decades with a 3/8" and 1/2" beam style torque wrench till a neighbor's garagesale had a TOTE FULL of snap on torque wrenches 15-20? of every size and type along with dozens of rebuild parts kits. He was a tech at a nuke plant and they didn't fix or recalibrate anything, just bought new.For the average home mechanic a simple beam style torque wrench is the way to go. You won't be searching for some weird ass battery every-fricking-time you want to use it.
I have to check the other un opened packages maybe I got the order right on them ?Mikey this is the style bulb you need for your turn signal.
https://www.amazon.com/Melphan-Auto-Reverse-12V-24V-Parking-Interior/dp/B08YDTJW5J/ref=sr_1_6?crid=3HC7VAMAD5EEM&keywords=led+1156&qid=1692105386&sprefix=LED+1147,aps,126&sr=8-6
