Just signed up yesterday. So if I break some unwritten rules of etiquette, please don't hesitate to let me know.
In the early seventies I owned more R3's R5's and RD350's than I care to remember. Since they were all pretty well wore out by the time I got em (I was poor), I spent in inordinately large amount of time at the Yamaha parts counter. Of course, to get to the parts counter, you had to walk past all the shiny new bikes on the showroom floor. Funny how they set that one up huh? Anyway, they always had a few brand new XS's setting out there and a ten min. trip to get parts would last all afternoon till the salesmen would chase me off so they could clean all the slobber off em.
Finally, around 78 - 80, I talked a salesman into trading me straight across 3 RD's for a used 76 XS. Man, it was love at first ride! I've owned 3 more since then. I've had lots of Beezers, Triumphs, and Norton's, and I swear the XS is still the best all around vertical twin ever built!
I bought this "bible" in 1980. It's a little dog eared, but it serves me well.
Jim.
Cylinders.. comment 26
Pistons.. 29
Discussion on polishing.. 32
Spring compressor.. 33
Valve grinder.. 38
Stud removal.. 43
XS1 pics..59
Paints used.. 63
First paint batch..66
Head bearings..78
Frame cleanup..85
Start of frame jig..91
Seat..100
Fork badge.. 103
More frame jig..111
More frame jig..119
Frame jig...done..132
Mounted frame..159
More frame cleanup..188
Painted frame (phew)..195
Head race removal mod..209
SS hardware polishing..219
Reg/Rec f&ckup..229
Reg/Rec test the right way..246
Fuse box mod..289
Fuse box plate..299
Steering head zerk..322
Minton fork mod..351
POR15 paint..371
Fork seals..395
Fork cleanup..402
Fork spacers..447
Little box on wheels buffer.. 475
Start of fork reinstall..485
Headlight bucket..500
Instrument buckets..515
Voltmeter.. 522
Front wheel and brake rotor..558
Front wheel mounted..584
Handlebars..611
Swingarm bushing mod..648
Swingarm installed.. 651
Rear fender..693
RLU wiring mod..699
Rear shocks oops..705
Rear wheel..713
Painted engine cases..730
Bottom end reassembly..744
Sump and cam chain..761
Engine stand..781
Top end buildup..811
Engine W&B..813
Engine hoist fixture..827
Engine install..845
Starter.. 850
Clutch.. 859
Grab rail..903
New seat..979
Rewound rotor..987
Stator..991
Timing..1000
Clutch seal mod..1015
First run..1035
Second run..1059
Carbs..1072
Floating heads 1084
Closed up headlight.. 1103
Front master cyl... 1111
Finished front brake.. 1131
Switch decals..1137
Exhaust..1173
Exhaust video..1197
Tank bodywork..1220
Seat..1236
Priming tins.. 1279
Jim.
Pistons.. 29
Valve grinder.. 38
Stud removal.. 43
XS1 pics..59
Paints used.. 63
Head bearings..78
Frame cleanup..85
Seat..100
Fork badge.. 103
More frame jig..111
More frame jig..119
Mounted frame..159
Reg/Rec f&ckup..229
Fuse box mod..289
Fuse box plate..299
POR15 paint..371
Fork seals..395
Fork cleanup..402
Fork spacers..447
Voltmeter.. 522
Handlebars..611
Rear fender..693
RLU wiring mod..699
Rear wheel..713
Engine stand..781
Engine W&B..813
Engine install..845
Starter.. 850
Clutch.. 859
Grab rail..903
New seat..979
Rewound rotor..987
Stator..991
Timing..1000
First run..1035
Second run..1059
Carbs..1072
Floating heads 1084
Switch decals..1137
Exhaust..1173
Exhaust video..1197
Tank bodywork..1220
Seat..1236
Priming tins.. 1279
